Gammal 2003-09-07, 23:01
rapid rapid är inte uppkopplad
Standard Fälgar, bultmönster?
Tjena! Funderar på att köpa fälgar till supran.
Vilket bultmönster och offset ska fälgarna ha?
Gammal 2003-09-07, 23:42
NorrlandsGuld NorrlandsGuld är inte uppkopplad
Skicka ett meddelande via ICQ till NorrlandsGuld
Standard Re: Fälgar, bultmönster?
Ursprungligen postat av rapid
Tjenare.
Orginal Supra MKIV 114.3/5 ET 50 men du kan gå ner på ET20 med rätt fälg.
Lycka till!
Gammal 2003-09-08, 20:42
Standard Fälg och däck info.
Were the Supra's wheels available in chrome?
Toyota itself never offered the Supra's 17" wheels in chrome. But many Dealers had the factory silver wheels chromed.
What about the 97-98 wheels, they look chrome?
They are polished aluminum, not chrome.
Which tires are recommended?
Michelin Pilot Sports, Yokohama AVS Sport, Pirelli P-Zero Rosso Assimmetrico and Bridgestone Potenza S-03 Pole Positions (in no particular order) are all great tires that are offered in many sizes commonly used on Supras. BFGoodrich g-Force T/A KD and KDWs are both good tires, but have a limited size selection.
What about putting wider tires (like 275s) on the stock wheels?
In my opinion, they are just too tall. I think a better size would be 265/40-17. It is actually much closer to being the same diameter as the stock front tire size, and are almost the perfect width. I don’t know why Toyota didn’t spec this seemingly more optimal size.
What are the diameters of stock vs. various other tire/wheel combos?
Front Tires:
Tire Size Total Diameter
235/45-17 (Stock Front) 25.33in.
235/40-17 24.40in.
245/45-17 25.68in.
245/40-17 24.72in.
255/40-17 25.03in.
265/40-17 25.35in.
235/40-18 25.40in.
245/40-18 25.72in.
255/35-18 25.03in.
265/35-18 25.30in.
275/35-18 25.58in.
Rear Tires
255/40-17 (Stock Rear) 25.03in.
265/40-17 25.35in.
275/40-17 25.66in.
315/35-17 25.68in.
255/35-18 25.03in.
265/35-18 25.30in.
275/35-18 25.58in.
285/35-18 25.85in.
285/30-18 24.73in.
295/30-18 24.97in.
315/30-18 25.44in.
What is the optimum tire section width for different width wheels?
8.5” - 235-245
9.0” - 255
9.5” - 265-275
10.0” - 285
10.5” - 295
11.0” - 305-315
11.5” - 315
What is the largest wheel and tire package I can put on the Supra TT without fender modifications, and with Eibach springs?
265/35-18s on 18x9.5" with a +50mm offset in the front, and 295/30-18s on 18x10.5" with a 53mm offset in the rear. The offsets are very crucial to make this work.(Information by Steve Jarvis)
What is the widest wheel and tire package that can be installed on a Supra with rolled or cut rear fender lips?
285/30-18s on 18x10” with a 47mm offset in the front, and 315/30-18s on 18x11.5” with a 45mm offset. The offsets are very crucial to make this work. Try at your own risk. (Information by Steve Jarvis)
What are the stock wheel’s offsets?
50mm front and rear
Is it safe to use wheel spacers?
No. Two things come into play when using wheel spacers. The first is the fact that less of the stud will be usable when installing the lug nuts. This means there may not be as much thread contact as there should be. Also, moving the tires outward, puts additional strain on the wheel bearings, and makes bearing failure more likely. You would not need wheel spacers if the wheels are the appropriate off-set.
Gammal 2003-09-15, 18:34
ok, tack för hjälpen!
Gammal 2003-09-20, 09:01
Klaus Klaus är inte uppkopplad
Hi
I run 285/30-20 on 10"x20 ET55 rear !
The tire clears the fender by 4,5 mm !
The car is lowered a lot and there is no bodywork done to the fenders.
Klaus
3,4L HKS Stroked, GT47-80, AEM EMS, SP400 Tranny, VeilSide IM, HKS 4" Hiper, HKS IC R, 20" AZEV, 6 Pot 385mm
6 x GReddy EW Gauges, FJO, TRD tacho/speedo, TRD Silver SW, HKS Drag Susp., TRD rear diff, lot of custom jobs, +1000 RWHP
Gammal 2003-10-12, 02:15
@lpher @lpher är inte uppkopplad
Ursprungligen postat av Klaus
Hi
Klaus
Any pics of these monster-wheels then? ;-)
@lpher
94 Supra TwinTurbo
Wingless/anthracite/auto
Gammal 2003-10-13, 22:07
Tjek this out:
http://www.horsepowerfreaks.com/Show...4&ModelCd=SUP4
Klaus
Gammal 2003-10-13, 22:29
How can you have run 11,1@0mph
Gammal 2003-10-13, 22:56
How comes you ask as much as my two daughters ...
Actually my sig on this forum WAS wrong - it has to be 11.14 as my ET brought to me had the reaction time taken out !
There were NO mesurements on the speed but my GPS logged signal showed 220 +/- "some" ... :D
Just didnt had that number/informations posting the sig.
Klaus
Gammal 2003-10-14, 00:02
Så man får inte fråga nått eller
BULTMÖNSTER APU Teknik Mkiv 12 2005-04-06 22:36
MKIV bultmönster Junior Teknik Mkiv 5 2004-09-10 07:44
Bultmönster till mk3?! Dunken Teknik MkIII/MR2/Celica GT4 3 2004-06-07 00:02
Bultmönster & offset på MR-2 -91...? Mattsson Teknik MkIII/MR2/Celica GT4 3 2004-05-02 13:20
Bultmönster? ie01gula Teknik MkIII/MR2/Celica GT4 2 2003-04-30 00:00
Alla tider är GMT +2. Klockan är nu 07:15.
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
